Murray 2510 no spark
Old 05-05-15, 09:22 PM
At the end of last summer a spring on the clutch broke, so I put the weed trimmer away for the year. I had no success finding the spring so I ended up getting a new clutch and replacing it. After putting it back together, and putting gas in it I could not get it to fire up. I was getting gas, but no spark, So I bought a new plug and gapped it and replaced it. Still it would not fire up. I am still not getting spark. So, what else might prevent spark?
Old 05-05-15, 11:13 PM
Piddler's Avatar
No offense intended, is the switch in the "ON" position?
Old 05-06-15, 01:32 AM
cheese's Avatar
Received 22 Votes on 19 Posts
Uplug the coil kill wire at the coil and make sure the gap is correct. If so and still no spark with the plug grounded, the coil is bad. Make sure you are grounding the plug when checking.
Old 05-06-15, 06:09 AM
Received 299 Votes on 273 Posts
How are you certain that it's getting gas? If it sat all winter without being used it's possible a jet or passage in the carburetor is clogged.
Old 05-06-15, 07:43 PM
No offense taken, yes it is on.
Old 05-06-15, 07:52 PM
I set the gap at .025, which is what I found on line. I will try the coil kill tonight.
Old 05-06-15, 07:56 PM
Well when I take the plug out and pull a few times you can smell the gas, and the plug is a little damp after gettting my workout pulling the string trying to start it.
