Older JD 14SE small mower
Old 05-09-15, 11:47 AM
2
I am dealing with an engine - Kawasaki FC150V - which has a lot of use on it. The engine starts easily but cycles on spark. It is hard to describe but almost like it the engine runs for two to three seconds with power, then runs for a similar period without firing. This pattern repeats but occasionally the engine almost sounds like it is running all of the time. However, even when it sounds like it is running all the time, it does not sound like it is up to full RPMs. Last fall when I put it away I allowed the engine to run itself out of fuel. I always put stabilizer in my fuel, and shut off the fuel switch before it went away. The mower operated twice this spring before it started acting up on its third time out cutting. Even when the engine is hot it starts up easily enough. It just is not running on every cycle of the engine.
I have done a compression test and it has 50 PSI. I pulled the plug and it looks light gray and is not wet with fuel.
I am going to throw a plug at it because that is cheap. What I want to know is this particular engine sensitive to brands of plugs? I pulled an NGK out of it.
Any other thoughts are welcome.
Steve
Old 05-09-15, 12:35 PM
P
Received 2,112 Upvotes on 1,891 Posts
Have you adjusted/checked the valves? Cold it should be .005" for both the intake and exhaust.
Old 05-09-15, 12:43 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Your carburetor needs cleaning. Old gas that was left in the carburetor has dried up and partially clogged a jet(s).
Old 06-17-15, 06:41 PM
2
Just wanted to let you know that debris in the carb bowl appears to have been the cause. The engine now runs fine. But I still have one small mystery. The carburetor is dripping fuel. I find fuel dripping off of the bottom. I have replaced the small gasket that goes on the nut that holds the bowl in place twice. Still drips fuel. Any other ideas?
Old 06-17-15, 07:22 PM
cheese's Avatar
The fuel inlet needle is leaking. Remove it, clean it, and use a qtip soaked with carb cleaner and push it up into the seat area to clean the seat.
