Craftsman 19 hp 2 plug mower
Old 05-17-15, 09:33 AM
knanuk's Avatar
The tractor portion runs perfectly -- until you engage the mower deck -- the engine makes a "popping sound" -- and the machine does not cut well -- stalls when cutting grass.
Does anyone have any ideas?
Thanks
Old 05-17-15, 09:49 AM
V
Received 2 Upvotes on 2 Posts
Are last year's grass clippings cleaned out from the underside of the deck ?
Old 05-17-15, 09:52 AM
knanuk's Avatar
yes they are the blades seem to be turning free -
Old 05-17-15, 10:01 AM
V
And I suppose the deck belt is self-adjusting ?
A loose/worn belt might present those symptoms.
Old 05-17-15, 11:23 AM
knanuk's Avatar
as far as I know the belt is not self adjusting -- I have a new one here so will spend the time to change it and see -- naturally it is a long weekend here and nothing is open --
Old 05-17-15, 11:33 AM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Is the engine popping or something in the deck? What engine is on it? 19hp two cylinder sounds like a 420000 series.
Old 05-17-15, 11:58 AM
knanuk's Avatar
The engine is popping -- the Model # is 944.606191
the engine is Model # 42A707-type # 1624-01
Old 05-17-15, 12:53 PM
BFHFixit's Avatar
Have you tried new plugs?
Also you might be able to identify which cylinder is causing it.
With the engine running low to mid rpm, using an insulated tool, remove one plug wire at a time and note any difference in rpm or popping.
Old 05-17-15, 03:42 PM
Received 30 Upvotes on 29 Posts
Sounds like an exhaust valve not opening fully. You may want to check the valve movement.
Old 05-17-15, 04:32 PM
cheese's Avatar
I agree with the notion that one cylinder is skipping and the suggestion to remove one plug wire at a time to find the skipping cylinder. It could be ignition related, fuel related, or even a valve seat that came loose.
Old 05-18-15, 09:33 AM
knanuk's Avatar
I am not mechanically inclined in the least -- I have pulled the plugs and they look OK -- Hit the carb with carb cleaner - the deck pulleys are not binding - and the same result - even going up a slight incline it is loosing power -- I will get a fuel filter tomorrow nd change that and hope that is it - otherwise find someone to put it on a trailer and take to repair as we live rurally
Old 05-23-15, 05:23 AM
knanuk's Avatar
Just an update ---- the problem was a blown gasket on the left side of the motor and a missing bolt -- this was remedied and all is like new -- at least for now--Thanks all
