Poulan lawn tractor doesn't run under load
My Poulan PR185H42ST lawn tractor with a B & S INTEK twin 18.5 HP 2 cylinder engine won't run under any load. I ran it out of gas last fall for the winter and left the switch on. Dead battery so I jumped it to get it started but it dies when I put it in gear. Also dies when I engage the deck. Any load and it dies. Anybody have any ideas?
You can't simply bypass the seat switch on some of these.
If it just stumbles and dies then I would suggest cleaning the carb. Fresh fuel, leave the air cleaner off etc.
This sounds more like a safety switch issue rather than fuel. A common way to isolate the problem is to disconnect each of the ignition kill wires from each coil leading to the wiring harness. That takes the safety switches out of the equation.
The kill wire is the small wire leading from the coil.
Yes. It dies when I try to engage the mower deck or engage the tranny when I let out the clutch. ANY LOAD ON THE MOTOR. And this all happened before I bypassed the safety seat switch.
