Wheel Horse mower
Old 06-05-15, 11:07 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Wheel Horse mower
Hi All, Wheel Horse tractor 13-38 XL, any ideas why it won't through grass into the bags,I have even tried without the bags an the chute still fills up but won't blow out,even with really dry grass.
Geo
Old 06-05-15, 11:31 AM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Do you have the blades designed to BLOW grass?
Are your blades worn too much to have the fan effect?
RR
Old 06-05-15, 01:55 PM
Geochurchi's Avatar
These are factory blades,a few years old,I can't remember if it worked any better when they were new or not.
Geo
Old 06-05-15, 03:42 PM
A
Received 73 Upvotes on 66 Posts
Rooster brings up a good point about blade wear. I have a recycling kit on my Toro, totally enclosed blades designed to lift the clippings higher and chop them up finer, so, granted, different mower and situation, but I see noticeably less desirable results as the blades wear, and often it has not been the wear on the cutting edge as much as on the sail, the flip at the back of the blade, which, if run long enough, will wear to the point that I could almost shave with it. If you plan to keep it for a while, you're going to need new blades at some point anyway, so might be worth at least trying a new set.
Old 06-05-15, 06:38 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Agreed, if it won't blow dry grass up the chute, then either the blades are turning too slowly or they are worn out.
Old 06-06-15, 04:33 AM
Geochurchi's Avatar
Cheese,what would change the speed?they are driven off the drive shaft of the engine.
Just curious
Geo
Old 06-06-15, 06:52 AM
cheese's Avatar
A slipping belt.
_____________________
Old 06-06-15, 08:42 AM
G
Received 23 Upvotes on 22 Posts
It's always a possibility the blades are on upside down, easy to do. Have a good one. Geo
Old 06-07-15, 04:42 AM
Geochurchi's Avatar
Thanks, checked that first.
Geo
