weed trimmer
Old 06-14-15, 08:25 AM
weed trimmer
Hi guys My current problem is with a Craftsman trimmer. It starts & will idle, but has little power. model #316.711370 I would Appreciate your thoughts about the possibilities. Thanks
Old 06-14-15, 08:29 AM
Received 128 Upvotes on 113 Posts
Look in the fuel tank and see if there's a filter inside the tank.
Broken or leaking fuel line.
Leaking primmer bulb.
Carb. needs rebuilding or replacing.
Old 06-14-15, 12:17 PM
W
Received 63 Upvotes on 55 Posts
Symptoms
What you describe is the symptom of a clogged muffler.
Old 06-14-15, 12:23 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Have you adjusted the two screws for mixture at high speed versus low speed? As Joe says, the filter may be clogged.
Old 06-14-15, 06:30 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
I'mwith Wirepuller38. Check it without the muffler.
