Problem with eletric clutch
Old 06-28-15, 01:10 PM
A
I changed the oil in my mower ( YTD24Y48 ) and spilled some of the oil on the deck. Now I'm having problems with the electric clutch engaging. When you turn it on, the blades will turn slowly for a few seconds then it just stops. There is a loud clicking when the blades are engaged and disengaged. Other than that the mover runs fine. It's only a year and half old. You can disconnect the belt and the spindle rotates freely. Any ideas? Thanks
Old 06-28-15, 06:07 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
The clutch is dependent on friction to work. Oil is designed to eliminate friction as much as possible. Put oil on a clutch... no workie. Clean the clutch disk mating area with carburetor cleaner or brake cleaner in a spray can.
