Anyone has manual xte1650 pressure washer manual
Old 06-29-15, 12:27 PM
V
Question Anyone has manual xte1650 pressure washer manual
Pressure washer is Xtreme Kleen and it says Midwest air technologies ... when I connect power cord to outlet it does not show any light ... it has two buttons test and rest ..I tried but nothing ... so I am looking for manual to find out if there should be light when I connect power cord to outlet?
or electrical wire is bad?
any comments would be of help...
also is there anyway I can change my username? if yes how?
Old 06-29-15, 01:02 PM
P
Received 1,629 Likes on 1,462 Posts
I assume the test and rest buttons you mention are for a GFCI on the power cord. Many, especially older models I've seen do not have a indicator light for power. So, does the pressure washer work?
I don't know of a way to change your username. You'll just have to abandon this name and re-register under a new name.
Old 06-29-15, 01:05 PM
V
Exclamation
NO it does not work ...and I checked fuse for continuity and it showed continuity so I dont think fuse is bad ...but fuse was all white inside that glass ...I have usually seen transparent fuse ...do you think that can be a problem?
also, when I looked carefully on gfci plug it says reset button will show indicator and test will turn it off and it does that so I dont think plug is bad ...may be long wire is broke somewhere?
Old 06-29-15, 09:39 PM
V
Ok I somehow started it but water leaks and no pressure or very low pressure
Please look at picture ..what is the solution...?
Do I have to take apart and because of this leak pressure does not build up?
Old 06-30-15, 11:52 AM
P
You said water leaks... Where does it leak from? Are you in an area that gets freezing temperatures? If so look over the pump housing very carefully for cracks.
Old 06-30-15, 07:33 PM
V
Well I found crack.... Thanks everyone..
Old 07-01-15, 06:57 AM
P
Ouch! Search online. Pumps are sold individually so you could keep the rest and just replace the pump section. You'll have to determine if it's worth the expense though. It might end up being about the same price to buy a whole new unit.
