John Deere LX178 15hp
Old 07-01-15, 12:00 PM
T
Exclamation John Deere LX178 15hp
Hopefully I can find some help here. I am a single mother trying to fix my riding mower myself to save money, but I have run into a road block. How in the world do I remove the pulley from the shaft coming out of the bottom of the engine. I am sure there is a easy way, but I have tried everything.
Old 07-01-15, 01:23 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Most mowers have a bolt up inside hollow shaft of engine pulley. Use an extension to get socket into tube and remove bolt. Pulley should then nearly fall off.
Hope this helps!
RR
Old 07-01-15, 05:19 PM
Received 128 Upvotes on 113 Posts
Why does it need to come off?
It would take an impact wrench to get the bolt off.
Old 07-01-15, 10:14 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Yeah, an impact wrench is usually used because the engine turns when you try to turn the bolt.
Old 07-02-15, 10:28 AM
G
Received 28 Upvotes on 27 Posts
If you need to lock the engine remove the spark plug, move the piston to the bottom of the stroke, load the cylinder with small rope like pull start rope, leave a little hang out, when you try to turn the engine the rope will stop it, when finished remove the rope. Have a good one. Geo
