24 HP Briggs Stratton
Old 07-01-15, 07:11 PM
R
What could be causing voltage regulator to short out???
Old 07-01-15, 10:22 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
You're putting new ones on and they short out?
Old 07-02-15, 09:40 AM
R
24HP Briggs Stratton
Put a used one back on it & it lasted for 1 mowing & it burned out.
Old 07-02-15, 11:41 AM
cheese's Avatar
Are you using a dead battery and mowing with it?
Old 07-02-15, 07:21 PM
R
It is a cub cadet with electric pto, has to have fully charged battery in order to operate.
Old 07-02-15, 10:19 PM
cheese's Avatar
So I'm assuming this means you have a good battery? I mean, if you're charging the battery before using it because it's dead every time... that would be good to know here. Feels like I'm pulling teeth.
Old 07-03-15, 10:08 AM
R
24 hp Briggs Stratton
Yes, charging battery before every time I mow. As of now have regulator unhooked, because it runs battery down & the wiring harness is hot to touch.
Old 07-03-15, 06:15 PM
cheese's Avatar
How old is the battery? There should be a code on a small round sticker that has a letter and number, like G2 or H1 or something similar.
Old 07-03-15, 06:38 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Cheese and runt61,
How about the possibility the battery has been reversed some time and blown the diodes in voltage regulator?
Have seen that happen a few times in my career.
RR
