Murray lawn tractor: dies when clutch is let out
Hello,
I have a Murray lawn tractor, model 425001x8B.
It dies when I let the clutch out.
Checked the 3 switches for continuity. All 3 check out.
I have removed and re-installed the switches multiple times, with no luck. Then, once, it kept running when I let the clutch out (so I cut the grass). The next day, it was back to dying when the clutch was let out.
If I keep the clutch/brake switch depressed by hand, the clutch can be let out.
It seems the PTO and clutch/brake switches don't seat terribly firmly in their respective slots (which are cut right in to the frame).
Would appreciate any help.
I have found two available switches, but would like to get help before ordering 2 switches.
Thanks in advance.
Thanks in advance.
That is usually a seat switch problem. Often it's a problem with it not plugging on tight enough to activate the micro switch in the connector (if your model has that).
