MTD Yard Machine Problems running
Old 07-14-15, 10:16 PM
C
Hello guys!
I am Camilo Pinzon, and write us from bogota, colombia!! I bought a Yard Machine 3 years ago, and I have problems when use the machine.
On sloping ground, the machine not run god, (the transmision its fine) its how the machine plug and unplug the transmision..!!! Im not sure what is the problem... The main problem, is that in COlombia not exist an service contact for this type of yard machine... and the aftermarket of this brand is really bad!!
I will record the machine running for explain better the problem, and see on the machine what could be the problem....
Thanks for your help!!! because my tractor is 1.5 year old unused,I need for cut around 2Ha (215,000 ft2) and nobody could help me..
Old 07-15-15, 04:10 AM
V
Received 2 Upvotes on 2 Posts
It sounds like the Drive Belt needs tightening; it's slipping when you attempt to go up a slight hill ?
This is somewhat common on a new mower . . . . after a break-in period.
Do you have the Owner's Manual ?
