McCulloch Eager Beaver MAC 100 Series Chain Saw
Old 07-15-15, 10:36 AM
F
When I inherited this saw, the piston was galled probably from using no 2-cycle oil in the fuel. I fixed that, got it started and it will idle. Now as soon as I feed fuel it immediately stops running. I have adjusted the low speed mixture screw, but to no avail.
Looking for any suggestions to get this saw running again.
Old 07-15-15, 11:21 AM
cheese's Avatar
Received 133 Upvotes on 122 Posts
Did you adjust the high speed screw too? You may need to open it up some.
Old 07-16-15, 06:20 PM
F
Yes the high speed mixture valve adjustment got it up to speed. It is still very temper mental and sometimes just stops on its own accord when idling. I suppose I need to fiddle with the carb adjustments. I also need to find some wood to give it a test under load.
