Craftsman motor will not staet
Old 07-16-15, 10:04 PM
I have a Craftsman riding mower. It has been running OK until yesterday, it started running rough so I put away until I could get some more gas. After putting the new gas in the mower wouldn't start. The moter is a craftsmsn 15.5 hp ohc. I have gas flow to the new fuel filter and it turns over ok but will not start. Any suggestions?
Old 07-17-15, 04:25 AM
V
Received 2 Upvotes on 2 Posts
I often start by pulling the spark plug and checking to see if it has been fouled; then evaluate whether it has been flooded; then check for a good spark.
Since you mention a "new" fuel filter . . . . has it run since that was installed ?
Old 07-17-15, 04:59 AM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
If it started running rough then it points to a carb problem. As Vermont stated check if the plug is fouled. The jets could be clogged or the float may be sticking.
