Clutch for old Super Tomahawk
Brand new to this forum. I just purchased an old Super Tomahawk chipper, model 4779 ST serial #W50223 with a 5hp Tecumseh engine. After using the unit for a short time the centrifugal clutch no longer engages. Any one know where I can get a replacement for the clutch.
5 HP Chipper clutch
Most of the units I have seen used a belt type clutch, as in you tighten the belt via an idler pulley to engage it..
But if its a centrifical clutch, you are then looking for basically Go Cart parts. Similar to this:Replacement MAXTORQUE PULLEY CLUT 255315
Of course the shaft size that it fits on, and the pulley size can vary, so you might have to look around.
If you can find out who made the clutch, there might be a rebuild kit for it..
