Broadmoor hydro 14 hp gave up mid-cut in the yard
Old 07-20-15, 06:56 PM
H
After a struggle to start - 2-3x longer than normal on the ignition key - indoor stored, elderly but has worked great for the past 4 years since I bought it , oil ok, battery on full charge - I ran for 40 minutes and managed most of the yard - then.... power gradually dropped then stalled and I was done.
A turn of the key 2 mins later gave 10 seconds of engine running, and 6' of movement but then nothing.
There is fuel at the filter, the starter turns the engine, but no firing up.
Anything I missed before I pull the spark plug ?
Thanks in advance
Malcolm
Old 07-20-15, 07:26 PM
Received 128 Upvotes on 113 Posts
At least 90% of the time it's a fuel issue.
Time to rebuild the carb.
Old 07-21-15, 11:15 AM
P
Received 2,118 Upvotes on 1,897 Posts
Hard starting, surging, needs choke to run or runs at one rpm but not others are all signs of a dirty carburetor that may have a jet or orifice plugged, or the float/needle valve not working properly. Another possibility is the valves may be out of adjustment especially if the engine has a lot of hours on it. That can cause hard starting and can cause the engine to sputter or die and may get worse when it gets good and hot.
Old 07-22-15, 08:01 PM
H
Thanks for that direction
I'll have a go in that area then
Cheers
Malcolm
