Kohler Courage 19 hp oil leaks
Old 07-24-15, 07:41 AM
D
I had oil leaking on the top of my Kohler Courage 19 in my Cab Cadet LT1042 (only 170 hours) . When I removed the plastic dressing cover I found the bolts backed off and one of them fell out of the top aluminum crankcase cover. I tightened all the bolts on the cover and cleaned up the oil. I washed it off then ran it for a little while trying to burn off the oil residue. I found a leak from a crack on the crankcase near the top RF corner of engine just below the cover area that I just put the bolts back in. I cleaned it up and epoxied it (nothing to loose by trying). It seems to have held ran it for 2 hours. Now, after sitting over night, I have oil leaking out the bottom of the engine and pooling on the pulley. I have not looked under there yet (just saw it last night) but wondered if there is a crank seal that could be my problem? If so do I need to pull the engine out to replace it? It was not leaking before I fixed the crack so is there something else going on, like high crankcase pressure, that I should be looking at?
Old 07-24-15, 11:46 AM
cheese's Avatar
Received 134 Upvotes on 123 Posts
Usualy if it's pooling on the pulley, it's because of the lower crankshaft seal. Make sure your oil isn't contaminated with gas.
Old 07-27-15, 09:05 AM
D
Drive Pulley?
I pulled the engine out to replace the crankshaft seal, but the drive pulley will not budge off the shaft. Apparently this is not that uncommon but I am not sure how to get it off? I do not have a press available to me or I would press it off. The pulley seems to be rather soft so I suspect that a jaw puller would destroy it (replacing it anyway) but not confident it would come off that way. Any suggestions would be appreciated.
Old 07-27-15, 05:02 PM
cheese's Avatar
I assume you got the bolt out of the crankshaft just fine. I usually use an impact hammer to get the pulley off the shaft. If you don't have one stop by a mechanic shop and ask a mechanic if he can use to to bump it off.
