craftsman rider trans issues
Old 08-03-15, 07:51 PM
Z
i have a 1996 craftsman rider I will look for the model number . I just rebuilt the engine and now the trans doesn't want to go into forward or reverse and brake doesn't work it will go into both modes eventually , but it won't stop in the process of fixing the engine I laid the tractor on its side, I've examined the linkage and don't see any damage. The only other thing that seems strange is the lever only moves half an inch to engage reverse but moves the normal distance in forward
Any thoughts ?
Old 08-03-15, 08:31 PM
P
Temporarily Suspended
Rebuilding the engine shouldn't affect the brakes or the tranny. There should be an adjustment on the linkage. Disconnect it for now, block the wheels & shift it into gear from underneath. If it goes into gear, it's probably an adjustment.
Are the brakes hydraulic with a master cylinder?
Old 08-03-15, 10:38 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
The brakes are mechanical. Working on the engine shouldn't do anything to change brake or trans operation. Since the problem of it not moving AND the brake not working both started at the same time, I would venture a guess that you removed one or both rear wheels while it was being worked on? If so, I'd say one or both axle keys fell out of the wheels.
Old 08-04-15, 04:35 AM
P
That makes sense.
_______________
Old 08-04-15, 03:02 PM
Z
Actually I didn't remove any wheels and didn't remove any linkage yet that's where the problem must be the brakes are mechanical . The only drive train parts I removed where the spring for the brake/ clutch so I could get the belt off
Old 08-04-15, 06:07 PM
Z
The tractors is a 917.257460
Old 08-04-15, 11:42 PM
cheese's Avatar
Is the transmission pulley turning when you're trying to get it to move?
Old 08-05-15, 05:17 AM
Z
Yes . It will move when it will go into gear, there doesn't seem to be any linkage adjustment except the tension for the brake
Old 08-05-15, 03:40 PM
cheese's Avatar
Okay, I was thinking it wasn't moving at all when I made my earlier reply.
Will the shifter move easier with the engine off? Or is it hard to shift then too?
Old 08-05-15, 06:58 PM
Z
Yes it's easier. It acts like there's a bind in the linkage it also wants to jump through neutral into which ever direction you want to go . It's also started acting like a slipping belt . As in there's a jerckeness in gear
Old 08-06-15, 10:24 AM
cheese's Avatar
Sounds like your belt is either incorrect or routed improperly. That can cause all your symptoms.
Old 08-06-15, 01:16 PM
BFHFixit's Avatar
[ATTACH=CONFIG]54273[/ATTACH]
Agree with belt or routing. Also possibly the spring for the idler (#18) is not connected properly.
With the parking brake on, the idler should release any tension on the belt stopping the trans pulley from spinning.
