Echo PB-500H not running
Old 08-07-15, 09:33 AM
G
I have an Echo PB-500H leaf blower that will not run. I bought it used so I took the carb apart and rebuilt it with all new gaskets and membranes as well as doing a thorough cleaning. I also removed the reed valves and cleaned them. I replaced the fuel line in the tank and cleaned the filter. With the spark plug out, cleaned and gap checked, it does spark when the rope is pulled.
If I put carb cleaner in the cylinder, replace the plug the blower will start and run for a few seconds but will not start at all otherwise.
Any suggestions as to what else to look for? I am assuming it is still something to do with the carb although I cannot see what.
Thank you.
Old 08-07-15, 11:27 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Put your thumb over the carb throat and pull to make sure you feel suction there. If so, I'd say you still have a carb related problem.
Old 08-07-15, 08:26 PM
G
I do feel some pulsing when I put my finger over the throat.
I will take the carb off again and go thru it with a fine tooth comb, again.
Any suggestions as to what to look for? Is there something I can soak the parts in to maybe dissolve any varnish that I can't see?
Thanx
Old 08-08-15, 03:31 PM
G
I decided to go thru the carb once again. There is a port on the carb that appears to have a screen filter in it and maybe some sort of black plastic disk. See the pic I have attached. You can see at the bottom of the picture there is the screen and the little plastic circle.
Old 08-08-15, 06:02 PM
cheese's Avatar
Yes, it is (was) a check valve. I suggest a new carburetor.
Old 08-17-15, 07:25 AM
G
I got the blower running with a new carb. The only problem I have now is that when I try to run it up to full speed it shuts off. It runs properly at a little over half throttle.
Any suggestions?
Thanx very much!
Old 08-17-15, 11:23 AM
cheese's Avatar
Can you get it to full speed by applying partial choke?
