InTek V Twin 22hp 725cc
Old 08-08-15, 04:40 AM
6
Help, My V twin started hunting rpm Governor keeps going up and down, and won't Idle, Cleaned carb new plugs etc. What can it be??
Old 08-08-15, 11:01 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Sounds like a plugged jet(s) in the carb. Applying partial choke smoothes it out, doesn't it?
Old 08-08-15, 02:12 PM
P
Received 2,108 Upvotes on 1,887 Posts
When you say "cleaned carb". How did you clean it? If you just sprayed a can at it that generally doesn't work. Often it takes removing it from the engine and disassembling to get at the tiny passages and orifices/jets that might be clogged.
