Toro 20334 lawnmower
Old 08-08-15, 12:35 PM
I fixed the gas leak; needed a new gasket; now when putting the lawn mower back together; it seems that the mower runs loud and the engine seems to be running, "fast" not the mower. Suspect something with the throttle but done know how to adjust it or did I not put it back together; any suggestions or comments would be appreciated. First time poster.
Thanks
-Jason
Old 08-08-15, 01:51 PM
Received 128 Upvotes on 113 Posts
Was there more then one hole in the linkage where the governor spring connects?
Did you bend the straight part of the spring while trying to remove it?
Old 08-08-15, 04:54 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
I agree, most likely a linkage is bent or out of place and up against something.
