JD 400 lawn tractor
Old 08-16-15, 04:05 PM
P
JD 400 lawn tractor
Having issues with restarting tractor after running for hrs of use. runs fine until you turn it off then will not restart. you can hear it click then nothing. any ideas? thanks
Old 08-16-15, 04:27 PM
Received 128 Upvotes on 113 Posts
All it takes is one loose or corroded connection.
Once it cools down does it start OK?
Old 08-16-15, 04:29 PM
Received 35 Upvotes on 34 Posts
It could be hot starter windings. That happens in trucks sometimes. Or it could be the battery after it heats up with use. Try jumping it with a slave battery. If nothing jump the hot cable to the starter and ground to the motor.
It sounds like the solenoid is working with the "clicking". Contacts can get corroded and cable ends need attention so if the starter works with the direct jump go through the cable ends.
