16hp simplicity
Old 08-31-15, 08:56 AM
G
16hp simplicity
What is the value clearance on a briggs 16hp model 1692112 gth . I've tried adjusting them at least 10 times and have no luck
Old 08-31-15, 10:18 AM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Engine model needed. .005" is usually good for both valves on most engines.
Old 08-31-15, 12:05 PM
G
Hi cheese model # is 303777 how do I know when to set the value.I keep trying but the engine still turns over hard
Old 08-31-15, 01:04 PM
G
Received 23 Upvotes on 22 Posts
When the piston is 1/4 inch past TDC on the compression stroke, remove the spark plug insert a screwdriver or something and to measure it. Have a good one. Geo
Old 09-01-15, 12:55 AM
cheese's Avatar
Correct, and be sure it's on the compression stroke, not the exhaust stroke.
.005" is good for both valves on that engine.
Old 09-01-15, 08:12 AM
G
THanks Guys Will see what happens
Old 09-03-15, 08:23 AM
G
Still having problems! Is the intake on top or bottom I'm guessing Top. Hear is what i'm doing first intake open then the exhaust when it comes up to top dead center I adjust the values. then I even tried the other top dead center no matter what it sounds like it pinging starts hard
Old 09-03-15, 09:36 AM
Received 30 Upvotes on 29 Posts
You want both valves closed to have the compression stroke. Then 1/4 past TDC and set clearances.
Old 09-03-15, 10:19 AM
cheese's Avatar
I suggest watching some you-tube videos about how to find TDC and how to adjust the valves. Getting it wrong can cost you internal engine problems.
Old 09-03-15, 01:21 PM
video
here's a link to part 1 of 2 by Dony boy on valves.
https://youtu.be/0cWoEk5Guos
Enjoy !!
