Help with generator plz
Old 09-09-15, 07:20 PM
K
So I found a generator that didn't run. I got it running really easy and found out it had no power going out so I did research and found out that they can go flat and u have to field flash them every now and then. So I reflashed it with a drill first and it worked but ones I shut the generator off and restarted it it had no power again. So I did it all again and nothing after it was off again. So I reflashed it again using a cord plug in and female end cut off and hooked to a 12v car battery and it worked till shut down. So now I have no clue were to look and could use help. It's a older multiquip 3600 .
Old 09-10-15, 11:58 AM
Received 3 Upvotes on 3 Posts
generator
Once you get it charging, you need to run it with a good load on it for a few minutes. At least this has worked well for me - good luck
Steve
Old 09-10-15, 05:10 PM
P
Received 2,180 Upvotes on 1,950 Posts
Running without a load means the generator doesn't have to work very hard with little magnetism. You want to create a strong magnetic flux to "set" the iron in the generators core so it will retain some residual magnetism when it's off. I plug in quartz lights (most are good for 500 watts each), space heaters, shop vac and anything else that draws a lot of current. Really make the generator lug. It will be good for the generator and a good test of your carburetor cleaning to make sure the engine can run under a full load.
