Bolens lawn mower does not stay running ..it starts but does not run
Old 09-16-15, 07:52 PM
V
Nodel no. is 11a-544l163 made by bolens.
I changed fuel and put new oil ... it starts but does not run
what should I look for ?
Old 09-16-15, 09:20 PM
cheese's Avatar
Received 44 Votes on 39 Posts
See if there is gas in the caburetor. Does it run longer if you leave the choke on, or are you even able to take the choke off before it dies?
Old 09-17-15, 06:07 AM
P
Received 586 Votes on 540 Posts
When you say it starts but does not run. What exactly do you mean? Is the starter turning the engine over but it doesn't run? Does the engine fire or sputter a few times and die or does it run for 20 seconds or more then die? I'm mainly wondering if the ignition is firing or not.
Old 09-17-15, 09:41 AM
G
Received 11 Votes on 11 Posts
I think the bowl nut is the main jet on that engine and it is probably clogged, remove the nut and clean it real good, one hole down the center and another across the bottom. Have a good one. Geo
Old 09-17-15, 10:27 AM
cheese's Avatar
I guess this is a walk behind then? If so, ignore my reply about the choke since it probably doesn't apply.
Old 09-17-15, 11:12 AM
V
Well after some adjustment to choke ....now it starts and runs both..before it was just starting for a couple of seconds before it died ...now it stay running but not in full force ...like goes little up and down ..not steady full power...I have added some fuel cleaner and will check after some time if that helps unless u have better idea
Old 09-17-15, 11:57 AM
I agree on the fuel problem. Take the bottom nut off the bowl clean bowl, run a bread tie in the holes in the bowl nut blow out the tiny holes and reassemble.
