16hp simpicity problems with pto
I have a 16hp M/N 1692042 having problems with pto replaced pto switch worked fine then just stopped is there a way of checking the switch and the clutch
Check the resistance across the 2 connectors on the PTO clutch and post the results. It may be a bad clutch burning up your switches.
Hi cheese Not sure how to read this thing but I put it on X1K and on ohms it was one short of 500 on the ohms scale
It should be less than 10 ohms. Make sure your meter is working right, and if so, I'd say the clutch is bad based on that reading.
The easiest thing to do is check for power at the clutch. If you have power and ground and it doesn't engage, then the clutch is bad. If not, go to the switch and check there. It can be tested with a meter though.
