How do you remove the auger assembly from MTD Yardman Housing
Old 11-03-15, 06:00 PM
I have a 1999 MTD Yardman Snowblower, Model 31AE6A4E000 that I need to replace the housing on. I cannot see how to remove the auger assembly from the Housing. I have the side mounting bolts removed and the entire auger assembly is loose.
Your help is appreciated.
http://i1142.photobucket.com/albums/...psbkkqajp7.jpg
http://i1142.photobucket.com/albums/...pszgp21cbi.jpg
Old 11-04-15, 04:53 AM
V
Received 3 Upvotes on 3 Posts
That Housing looks pretty good . . . . why do you need to replace it ?
I just did that disassembly this past Spring when I added "Paddles" tp the Impeller Blades.
It appears that you got the Bolt and Pulley off the Impeller Shaft and now have a stuck Bearing.
I had to drench my Bearing in Penetrating Oil for several hours and then borrowed a "Puller" to get it to budge. I have since purchased a Puller of my own, similar to this:
http://http://www.ebay.com/itm/2-65mm-Two-Jaws-Gear-Puller-Bearing-Disassembly-Tool-Spiral-Forging-Technology-/111734494877?hash=item1a03e5169d
If it has never been off since 1999, it may be a struggle, so be patient (and protect the bolt's threads at the end of the Impeller Shaft).
In case you're interested, here's a photo of my Impeller with the Paddles attached:
PS: eBay also has replacement Impeller Bearings incase thise one is over the hill !
