poulan chain saw won't start
Old 11-24-15, 08:55 AM
E
I have a Poulan 2075 chain saw. I replaced the bulb and all the gas lines. Now I can't get it to start. I checked that the lines are correctly connected: the small diameter line has a filter and goes from the gas tank to the top of the carb, the bulb line TANK uses the larger line to the tank, and the bulb line CARB goes to the lower part of the carb. When I pull the plug it is wet and I can see a spark.
Old 11-24-15, 10:29 AM
cheese's Avatar
Received 141 Upvotes on 130 Posts
If the plug is wet, the saw is flooded. It could be that the carb is leaking. Try to start it with full throttle and no choke. It may take 20 vigorous pulls since it's flooded, but see if it will. Sometimes the carb will work itself out when the engine starts, sometimes not.
Old 11-24-15, 02:33 PM
B
Received 289 Upvotes on 257 Posts
If the carb is a ZAWA, you have the gas lines reversed at the carb.
Old 11-25-15, 06:03 AM
Received 34 Upvotes on 33 Posts
Here's a routing diagram from Fixya:
Old 11-25-15, 10:00 PM
The metering diaphragm may be hard and is holding the needle open to allow fuel to flow into engine.
