Average compression psi on lawn mower engine
Is there a general compression test value on a 15 year old lawn mower engine showing the compression is ok?
If you are having trouble with the engine I much prefer a leakdown test. A compression test will just provide a compression number. A leakdown test will also show good or bad compression and allow you to determine where a problem lies; blown head gasket, leaking intake or exhaust valve, worn piston or rings or cracked head...
12v802 bs flat head engine
This engine starts pretty well but consumes a good amount of oil. I can't see smoke except at start up (smallish amount) I believe I measured about 65 on the compression test.I'm considering rebuilding it because it is easier to push with bearing wheels and has been dependable.I'll check into a leak down test.
I think B&S used to say if you pulled on the starter rope without your foot on the mower and it started to lift the mower the compression was good. Have a good one. Geo
I have a Troybuilt with bearing wheels and a 6.5 hp Briggs on it. Very easy to push and very quiet.
Look under your the deck and see if the seal is good. That won't be a compression issue but you might see where your oil is going.
Try to use another comp gauge to see if the two match.
