Cranking generator
Old 12-13-15, 06:21 PM
W
Cranking generator
I have a generator that the rope pully is damaged so I removed cover and welded a socket on to extension to fit nut so I could turn motor to crank.My question now is which way should I be spinning pully to the right or to the left.Thanks for your help
Old 12-13-15, 06:27 PM
All engines turn clockwise !!~!~!
Old 12-13-15, 06:38 PM
Received 3,419 Upvotes on 3,065 Posts
Question.... now...how will you turn that nut.... and how will you get the socket off once it's started ?
Old 12-13-15, 07:40 PM
A
Received 4 Upvotes on 4 Posts
You should not use the nut to crank the engine it will over torque the nut and could break the flywheel.
Old 12-14-15, 04:27 AM
Norm201's Avatar
Received 670 Upvotes on 593 Posts
Not to mention that the recoil may break your arm.
Old 12-14-15, 06:26 AM
B
Received 47 Upvotes on 43 Posts
As one who owned a Hillman car with a broken tooth on the flywheel back around 1960, I used to hand crank it when needed. Point being, that kickback can be mean. Not sure where that long ratchet arm will land??
Bud
Old 12-14-15, 10:19 AM
When I was building racing engines for sprint karts we used a motor powered by a battery (car) to start our engines.
Some people use a 15/16 socket on a 20 volt cordless drill.
