Honda snowblower carburetor problem revisited
Old 12-13-15, 11:34 PM
H
A few years back I started this thread:
http://www.doityourself.com/forum/ou...uestions.html?
I have the same problem again. The replacement carburetor is allowing fuel to leak out. I've fiddled with it a bit and I can't seem to get it to stop. Last time, a rebuild kit didn't help so I had to order a new carb.
It's worked good for 5 seasons. I use only Ethanol free fuel with Stabil. None of my other lawn/garden engines have this problem.
Old 12-14-15, 03:16 AM
31YTech's Avatar
Hello HRTKD,
Aftermarket carbs are cheap enough now (Ebay) that it doesn't pay to fool around with one, just replace it and be done.....
Good Luck
Old 12-14-15, 05:46 AM
Received 128 Upvotes on 113 Posts
You have some trash in the needle seat area stopping it from sealing.
Float bowl has a hole in it so it no longer floats.
Needle or float is sticking.
Pick one.
All this should be able to be checked by removing the float bowl.
Old 12-14-15, 06:26 AM
P
Received 2,190 Upvotes on 1,959 Posts
Did you get a OEM or cheap aftermarket one?
Even gas with stabilizer will go bad. Stabilizer only slows the varnishing process and unfortunately it can't stop condensation, rust and dirt accumulation. So, you may still have a problem caused by old fuel.
Old 12-14-15, 07:41 AM
H
The replacement carb was OEM Honda. $58 at the time, now $64.
I took apart the float bowl last weekend, including the needle. I sprayed it down with carb cleaner and then reassembled it. No joy, it still leaked.
