Throttle linkage for 8 HP Tecumseh snow thrower
Old 01-01-16, 07:41 PM
W
I have a 536.886280 craftsman 8 horsepower 26" snow thrower, Tecumseh carb and need throttle linkage help. All info I see shows 2 throttle linkages and I have 3. I need help placing all three linkages. Thank you, Garry
Old 01-02-16, 01:56 PM
31YTech's Avatar
Hello Garry,
Can you look on the engine flywheel cover for the model and possibly a spec. number, with that I can see which control assembly you have.....
31
Old 01-02-16, 07:10 PM
A
Received 4 Upvotes on 4 Posts
You should only have 2 links but post a picture of what you have
Old 01-03-16, 06:43 PM
W
Will this help? Sears, Roebuck & Co. 143.948001
Model Number 536.886280
Code 428303793
I have the two rods shown but still have a third rod with a spring.
Old 01-04-16, 07:32 AM
A
The picture that I posted should be your setup. The extra link & spring must come from some other machine.
Old 01-04-16, 07:57 AM
W
Nope, came from this machine.
The only project I am working on is this snowblower. I am usually very methodical about reverse engineering. I put bolts back in the same hole for later assembly, etc. however, when I removed the carb, the linkages all come off before I made any notes. The three linkages are from this machine.
Old 01-04-16, 11:58 AM
31YTech's Avatar
Hello Garry,
After some research (memory fading) I believe the link with spring goes where the red box's are, with the spring on the governor lever.....
Good Luck
Old 01-05-16, 02:02 PM
W
linkage
Thank you for the extra info. I will give this a try in the next couple of days, hopefully, before it snows...Appreciate your help...
