John Deere gator no fire
Old 01-07-16, 11:02 AM
I replaced coil on John Deere amt626 gator 2 months ago. It now has little or no spark. It has Kawasaki fe290d192851 engine. Could it be the igniter bad?
Old 01-07-16, 11:54 AM
cheese's Avatar
Received 21 Votes on 18 Posts
Yes, it could be.
_________________
Old 01-07-16, 03:36 PM
31YTech's Avatar
Hello Scslattery,
Mr Cheese is correct, If you have a multimeter you can perform the following test to assure that is your issue before replacing it. Just choose the one that looks like what's on your unit.
Good Luck
Old 01-07-16, 03:48 PM
BFHFixit's Avatar
If it does test bad, a replacement can be found much cheaper than JD will sell it to you for. I think there are at least two after market ones, I have used the rotary part without any problems.
The part number has been posted in these forums previously, and likely 31 knows it off the top of his head
