Black Max generator Honda engine
Old 01-16-16, 12:38 PM
Black Max 8750/7000 with Honda engine. The rpms will go up manually by moving throttle wire. Rpms will not stay up enough to power equipment when running on its own. This just suddenly happened.
Old 01-16-16, 02:45 PM
31YTech's Avatar
Hello jackie585858,
The high speed RPM is adjusted with the phillips screw in the red box below, make sure the governor spring between the lever this screw adjust to the governor arm on top of the engine is in-tack. Correct RPM's should be 3600......
31
