Generator receptacle broken and display dead
Old 02-07-16, 07:14 AM
Hello -
I have a Ridgid 6800 Watt generator that has a broken GFCI receptacle and the display doesn't work. I tested both sets of receptacles and neither has power. I suspect that's why the display doesn't work. The 220 receptacle does seems to work.
Can I just replace the broken GFCI receptacle with a new one? Is there anything special I need to know? Is the broken receptacle the reason the display doesn't work?
Thanks for your advice!
Old 02-07-16, 09:31 AM
Received 3,973 Upvotes on 3,566 Posts
I would doubt the broken receptacle is affecting both receptacles or the display.
Did you make sure all the circuit breakers are pushed and locked in all the way ?
The two receptacles and the display are in a removable enclosure that has two plugs on the back. Have you removed that panel to make sure the plugs are on ?
Old 02-07-16, 11:29 AM
PJmax - yep. You were right. The big twistlock was disconnected. The display came right up after I connected it.
I replaced the receptacle too. No surprises other than the price of black GFCI receptacles!
Thanks for your help!
Old 02-07-16, 11:32 AM
Too bad you weren't closer. I have a case of black GFI receptacles.
They're a big hit in most houses.
