Fuel line specifications for Ryobi RGBV3100 Blower
dan125's Avatar
GA
03-10-16, 04:54 PM   #1
I'm trying to revive a Ryobi RGBV3100 Blower /VAC and need to replace the fuel lines but don't know the Inside and Outside Diameters and if all three fuel lines are the same size. I've spoke with MTD and their rep was not too sharp and couldn't give me answers I trust, Trying to avoid gas leaking all over the place.
goldstar's Avatar
OH
03-10-16, 06:37 PM   #2
First mark and draw a sketch of where each fuel line goes. Then pull the lines and take them to a lawnmower repair shop. They will match the lines and have the correct size(s) in stock.
Get a new gas filter too - goes on the suction line in the tank.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
dan125's Avatar
GA
03-12-16, 02:04 PM   #3
Thanks - problem is that the lines are no longer attached and the ends are too damaged to use. Was hoping someone had a service manual that has specs. May have to go trial and error.
CarbideTipped's Avatar
OH
03-12-16, 02:12 PM   #4
If you search for it on Partstree you'll get the full engine diagram and part numbers for the fuel lines. They probably won't give diameters, but the official parts are often inexpensive and available from multiple sources.
Paul
Inside every small project is a big project waiting to slug you over the head and take all your money and time....
