Poulan chainsaw not sawing
Old 04-04-16, 09:44 PM
L
I own a Poulan Pro 4215 avx gas saw and when I crank it, the chain moves until I put it to the wood, then the chain won't move though the engine still runs.
Is this a clutch problem or is it something else?
Old 04-04-16, 10:03 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Most likely the sprocket is worn out.
Old 04-05-16, 07:06 AM
W
Received 63 Upvotes on 55 Posts
Clutch
Check the clutch for saw dust and debris. May be too clogged to work properly. Also, make sure the chain brake is not engaged.
