Husquvanra weed wacker
Old 05-06-16, 02:54 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi All, can't get this started,rebuilt Walboro carb,fresh gas,good spark,floods cylinder even with needle valves seated all the way in,tried to spray starter fluid in cylinder,still would not bark!
Old 05-06-16, 04:49 PM
Received 126 Upvotes on 111 Posts
Not going to start until you address that needle valve issue.
Old 05-06-16, 10:25 PM
Those are my favorites I got 3 of them ~~~
2 of the 128 and a 124 What's up with yours a stale fuel issue ??
Old 05-07-16, 09:47 AM
Geochurchi's Avatar
Fresh fuel,cylcinder floods even with the needle valves seated in all the way,where should they be set for initial start up? I have no info on this machine i.e. Model #
Old 05-07-16, 12:14 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Have you checked the fuel inlet needle? Sounds like it's not shutting off completely for one reason or another, or the fuel lines are connected wrong.
Old 05-09-16, 05:42 PM
Geochurchi's Avatar
I will take it apart shortly and double check to be sure it is adjusted correctly,any idea how the needle valves should be set for initial starting? It is a K20 WAT carb,fuel lines are correct.
Old 05-09-16, 09:09 PM
yes a K 20 will do the job. Some call for a K 10 and it needs a 20 !!! SMH
If you have a W for adjusting look on the tool for the initials on the tool or Hda ETC. I know the carbs pretty well and I do use the tool sometimes.
Old 05-09-16, 09:12 PM
I go 1 and 1 1/2 turns on each then go from there on the adjustments ~~~
Old 05-10-16, 02:16 PM
Geochurchi's Avatar
Only 3 screws ,H L and idle, no tool required just a screwdriver.
Old 05-10-16, 07:37 PM
Is your carb still flooding ??
Old 05-11-16, 02:47 PM
Geochurchi's Avatar
Still flooding although I have been able to get it to fire up a couple of times,which screw should be 1 turn out,I hate adjusting carbs!
Old 05-11-16, 02:59 PM
Geochurchi's Avatar
Old 05-14-16, 08:49 AM
Geochurchi's Avatar
Here is an update,I have adjusted the fuel inlet needle and can now get it started,however it will only stay running as long as the trigger is squeezed in ,needle valves are out 1 1/2 turns each where do I go from here?
Old 05-14-16, 12:35 PM
cheese's Avatar
Of the two mixture adjustment screws, the one closest to the air filter is the high speed one, and the one closest to the engine is the low speed. I think you need to back out the low speed one a bit until it idles well.
Old 05-14-16, 09:22 PM
Yes I agree with cheese the L Is closer to the engine.
Back it out just a bit like a 1/8 turn. Then crankk kkk till you arm falls off lol.
Choke 3 pulls will help then when it does pop let it warm up. If it dies throttle a lil bit. Try to get it it to idle with the L.
When it does leave it alone and go to the H screw. then adjust that one for rev then back off on that one a hair.
It doesn't take much of a 1/8 of a turn to make a big difference !!
Old 05-18-16, 01:09 PM
Geochurchi's Avatar
Success ! I have managed to get the idle set,the wacker runs great now.
Old 05-20-16, 08:01 PM
How did you adjust it ?? Tell us so other people can learn too ~!~!
Old 05-21-16, 05:07 AM
Geochurchi's Avatar
Well,I primed it carefully not to flood it,when it started I feathered the throttle while adjusting the "L"screw until I got it to idle,I did read that to adjust the "H" screw you hold the throttle wide open and adjust it from there finding the sweet spot, haven't tried that yet as it seems to run OK.
