Echo PB4600 backpack blower won't start
It seems as though, rather suddenly, my backpack blower won't start. The primer bubble had cracked so I replaced it and now it won't prime. I checked both fuel lines and blew them both out and they seem clear. I tried spraying some starter fluid in it and firing it up and it would start, run for a few seconds, and then stall out. I tried adjusting the idler screws on the carb but nothing worked. I replaced the fuel filter as well but then I noticed this:
Is there supposed to be another small hose attached to that connection? Could that be why it's not priming?
The PB-4600 is a common blower, not sure why the site wouldn't show it.
There should be a fuel line with a filter on the end that drops down to the bottom of the tank on the inside part of that tank grommet. I recommend replacing the whole grommet/fuel line assembly. It comes in a kit for $15 or so if I remember right. Any echo dealer or many small engine shops should carry it.
I'm really late revisiting this but better late than never.
I replaced the grommet on top of the tank and blew out the fuel lines clean. I also replaced the fuel filter but the problem I'm having is that the primer bubble still won't pull fuel in to prime the engine. This is a bubble that was replaced shortly before I ran into the issue of the blower not working.
The way I've come to understand it, the old bubble rupturing may have been the symptom of a pressure buildup in the system and the rupture was the manifestation of that problem. However, it may still exist so I decided to get a brand new carb, but I'm still waiting on the gaskets from Amazon.
My question is this: Do I need to do any fine tuning on the new carb or can I just swap it out?
At this point, if this doesn't work it's going to have to go into the shop unless someone has another suggestion.
Another quick update, I bought the new carb for about $40 and swapped it out. It works like a charm now and the power levels are better than I ever remember. I also took the opportunity to rebuild the old carb so at least I can learn something about how they're put together and it took about an hour. I soaked it in cleaner and replaced all the gaskets. Just to see if I screwed anything up, I swapped out the rebuild with the new one and it works just as well so now I have a spare if need be.
Thank you all for your help.
