Possible to install a larger deck?
Old 05-18-16, 08:17 AM
N
Now that I appear to have finally got to the bottom of getting my mower starting every time, I am looking at what I can do to it that will make mowing my yard a little easier. The first thing I can think of is can I replace the deck, it currently has a 46" deck on there which I would like to replace with a 54" or possibly a 60" if one were available.
However, I am having a hard time finding something which I know will fit. Likely due to the fact that my tractor is a few years old. Does anyone know first of all if it is possible to upgrade the deck? and secondly of any 54" decks that will fit a White Outdoor GT2150?
Thanks.
Old 05-18-16, 11:25 AM
cheese's Avatar
Received 22 Votes on 19 Posts
Not sure what you have on it for an engine but a 54" deck takes some horsepower... is your engine big enough?
Old 05-18-16, 12:10 PM
N
It's a 22hp Tecumseh V-twin, whether that is big enough I do not know. Engine model is OV691EA.
Old 05-18-16, 04:39 PM
Received 47 Votes on 42 Posts
Going to be real lucky to even find a larger deck for a White Mower, fit or not.
Time for a new mower.
Old 05-18-16, 05:12 PM
chandler's Avatar
Received 4 Votes on 4 Posts
I did some research on your mower, and no where did I see the feasibility of adding a larger deck. The 46" was as large as they went. I'm not sure whether a 22 horsepower gas engine will pull a larger one. I have a 60" steel deck on my 21 HP ZTR, but it is diesel, so there is a difference.
Old 05-18-16, 05:48 PM
cheese's Avatar
I looked at the attachment system and it's a common one that is used on ohter deck sizes as well. There shouldn't be any problem finding decks, it's a MTD and I think I even have a extra deck or two around that will fit it. I don't think they make one bigger than a 50" that will fit though. Not sure if it's worth the hassle and expense for 4 more inches of cut though.
Old 05-19-16, 06:41 AM
N
Not in the habit of throwing money away, the mower works fine, would have just been nicer to increase the deck size. Certainly not worth spending the $2,500 minimum to get one with a bigger deck.
I agree, for 4" additional inches it's not going to be really worth while.
Old 05-19-16, 11:02 AM
W
Received 7 Votes on 7 Posts
Widen Mower
Look into a towable, outrigger mower to pull behind your existing mower. Would double your mowing capacity
Old 05-21-16, 05:57 AM
mower deck
My son in law has an older wheel horse. He cut an extra deck in half, and welded it on to one side of the existing deck. Rigged up a belt, and it works great. Just have to be careful not to get too close to trees on the side with the extension!
I guess anything's possible. Steve
