Choremaster power washer: help with future winter storage
Tried to use the power washer today. Could not get any pressure. Took the inlet apart and found rust clogging the INNER screen. I cleaned it up and got all the rust out. This also happened last year. I do use pump saver before I put it away for the winter. Is there anything I can do in addition to the pump save to prevent this.
There is the typical hose connect fitting first, then the fitting I am referring to is next. With the first fitting removed, the second is accessible to spray something in it etc. They are both threaded fittings. It is a horizontal pump.
Seems odd that it has a screen that would rust. Normally they are brass or stainless. I don't have a recommendation other than trying to squirt oil on it before storage.
Thinking about it more, I would almost bet that the screen IS stainless or brass and you are catching rust from old iron pipes in your supply. You could add a filter before the pump.
Cheese, you are correct, it is stainless steel. I never thought about it being rust from the pipes or water supply. We have 100% plastic pipe in our house including the well point. I have a whole house filter in the system. Before I put in the filter, we did have rust in the spigots. Thanks,
