Troybilt pony mower wont move`
Have a troybilt pony rider that wont move forward or reverse help please? Ps belt isnt broke or off of it!
Need the model number of the mower for starters.
Most newer mowers have two belts, one for the blades, one for the hydraulics.
Troy-Bilt Riding Mower - 13AN77TG766
You say belt as in singular. Unless you have a hydro, you have more than one motion drive belt. Loose isn't good on the motion drive belt.
The long one is likely the blade belt, need to be looking at the short one way up under the frame.
It should be tight enough to play a tune on it.
Once I had the spring break on the idler pulley that holds the tension on the belt.
Another time the bolt was so over tightened right from the factory the idler could not move enough to keep the belt tight.
Ty joecaption for the info ill tell my son to check all of that. I have had 2 strokes and cant do much but this info is very helpful ty. I check back asap to let cha know if it worked or not
