Craftsman tractor: had a bad day
Old 06-04-16, 07:33 AM
C
Angry Craftsman tractor: had a bad day
OK, I have a craftsman lt1000 riding mower. Yesterday I had two problems with it.
I hit a rock in my yard and the bar that attaches to the ball joint to rotate the front wheels popped off. I put it back on the ball joint, but it does not stay very well. Slight vibration makes it fall right off, and the steering becomes useless. How do I fix this? Do i have to buy a new part, and if so what is it called?
While trying to fix the first issue, the mower stopped turning over. I turn the key, and it just makes a high pitch RRRRRRRR noise from up front. What happened? Did I over load something? I took the battery off and checked it, its a bit low so I put it on a charger. Any ideas?
This mower is second hand, and may be on its last legs. Currently sitting here, salty as heck, waiting for some kid to come and give me a price on cutting my lawn.
Old 06-04-16, 07:39 AM
C
Received 134 Upvotes on 110 Posts
The full part no. of the mower would help us identify the exact mower you have. Should be on a sticker on the mower.
Old 06-04-16, 07:42 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
There should be a tag on mower with model #. Please post # so we can see the parts you are talking about. After battery is charged does it still make rrrrr noise?
Old 06-04-16, 08:56 AM
C
Mod No.
Mod No. 917.270532 Ser No. 071200C026708
Battery Still Charging.
Old 06-04-16, 12:42 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
You need a drag link #1926091 to fix the steering problem... it's a normal wear part.
The spinning sounds like the starter gear is not kicking up and engaging with the flywheel. Could just be dust and dirt that needs to be cleaned off or the gear may have broken. If the gear is broken, buy a genuine replacement gear from briggs for 5 or 6 bucks, don't be fooled by the 99 cent ones online. They are junk and sometimes break before starting the engine one single time.
Old 06-05-16, 08:11 AM
Battery may be going bad.
