35 HP Vanguard - Briggs & Stratton Won't Start / Crank
Old 06-22-16, 08:14 AM
Question 35 HP Vanguard - Briggs & Stratton Won't Start / Crank
Hey Guys,
I have a fairly new 35 HP Vanguard engine that will not crank.
It would attempt to crank the other day, but the connection @ the positive battery post would get hot and smoke. I assumed this was just a weak spot due to the undersized / under gauged connector.
I replaced the entire wiring system with 10 gauge wiring and replaced all of the connections from the solenoid to the battery. After doing so, it did a half crank then everything died!
I am sure something fried, but I am not sure where to start.
Can it be a fried solenoid? Fried Starter? Fried Switch? Ignition coils?
What are your thoughts?
Old 06-22-16, 11:05 AM
cheese's Avatar
You're using 10 gauge wire to crank a 35hp engine? You might have burned the wires in half. That's not nearly big enough.
