Honda Harmony 215sx: carb removal
Old 06-30-16, 05:05 AM
C
Received 25 Upvotes on 22 Posts
I picked up this mower for free off Craigslist. The gas smelled rotten so i tried to remove the carb for cleaning. On other mowers this means removing bolts, but this carb slides onto threaded studs and is secured with nuts. When I try to slide the carb off the studs, the deck gets in the way and the bowl nut hits a surface on the deck. There is not enough clearance between the deck and the carb to remove the bowl nut (which would allow the carb to slide off the studs).
Can i back the carb mount studs out by unthreading them, or are they permanently installed? There are no squared wrench points on the studs, i thought i might threadlock two nuts and wrench at the nuts. I'd hate to have to remove the engine just to get at the carb.
What's the right way to do this?
Old 06-30-16, 11:37 AM
cheese's Avatar
Received 141 Upvotes on 130 Posts
I jam two nuts together on each stud and use them to back the studs out as you suggested.
Old 06-30-16, 11:40 AM
C
Thanks, I'll take a shot. I just realized I'd only have to remove one stud, then tilt the carb sideways a bit to slide it off.
Old 07-04-16, 05:48 AM
C
Thanks again, the idea to unthread the studs worked. I put 2 nuts on the stud and tightened them against each other, then turned the "inside" nut to turn the stud. Cleaned the carb and got floating crud out of the tank, gassed it and it fired up.
