Stihl chain saw won't start
Old 07-15-16, 09:48 AM
I have a STIHL MS180 chainsaw that I bought used on craigslist. It was not running when I bought it. The tailpipe was all clogged up with some greasy substance so I wiped it really good and rinsed it with warm water. it starts up and acts like it wants to run , but then it bogs down and dies. anyone have any suggestions on what i should try? I have attached a link to a sound clip of me trying to start it.
https://clyp.it/lnlbvnrb
Old 07-15-16, 10:58 AM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Sounds flooded. Try without the exhaust. If it still does the same, reset the mixture screws on the carb.
Old 07-15-16, 11:19 AM
Ok so I have already tried removing the muffler. It will not start at all without the muffler, and it smells like Gas really bad. Thinking that it might not run without the muffler because it needs the backpressure, I had my wife stick her finger in the exhaust wile I gave it a full choke. still nothing. I will try resetting the screws when I get home today, but I think there has to be something else weird going on.
Old 07-15-16, 01:19 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
How is the spark plug,and are you using fresh gas,have you checked the fuel filter?
Old 07-15-16, 01:41 PM
spark plug was covered in crap and really hard to remove when I pulled it out the first time. so I cleaned it off really good and gently re-inserted it. I'm using brand new gas and the fuel filter seems clean. Even with the freshly cleaned plug,I yanked it until I was red in the face and it just wont run. Pulled the plug back out and its covered in crap again.
Old 07-15-16, 05:10 PM
Received 125 Upvotes on 110 Posts
Replace the carburetor, sounds like the floats sticking.
It's cheaper to buy the repair kit but there's so many tiny parts to deal with and small orifice's I find it far faster and easier to just change the while thing.
Old 07-15-16, 05:44 PM
Geochurchi's Avatar
I would start with a new plug gaped correctly,ground the plug to the block and turn it over and see if you get a good spark,if so put a teaspoon of gas into the cylcinder,install the plug and see if it will fire up,I might even dump some misery oil in the cylcinder and turn it over a few times to clear the crap out of it,if there is that much crap in there then that carb needs to be rebuilt also.
Old 07-15-16, 06:21 PM
BFHFixit's Avatar
If you find a float in that carb, let me know please
Indeed try a new plug and not a used cleaned one.
What kinda "crap" is the plug covered with?
Old 07-15-16, 07:48 PM
cheese's Avatar
I should run without the muffler. It's flooded. Are you trying to start it with ful throttle? Give it full throttle and no choke at all and pull it several times and see what you get. Any choking is going to make it worse. If it starts, keep it at full throttle until it clears the crud and smoke.
