21 hp pumps oil out filter of fuel pump when reved up and smokes bad
Old 07-30-16, 09:35 AM
W
21 hp briggs 2009 model 3318 77 0142 B1 smokes a little when started Then as you throttle up the machine starts to spew oil out the tiny brass coloured filter on the fuel pump and then really puts out oil smoke
Old 07-30-16, 10:48 AM
BFHFixit's Avatar
Head gasket ?
Old 07-30-16, 12:16 PM
cheese's Avatar
Received 141 Upvotes on 130 Posts
It sounds to me like your oil level is overfull and probably thinned by fuel. Check the level, smell it for gassy smell. If so, you have a leak. Either the fuel pump is leaking through the pulse line or the carburetor is leaking. This is the most common reason for your problem, but a head gasket is a possibility if there is no fuel in the oil.
Old 07-31-16, 11:23 AM
W
thank you for your advice
