13hp Tecumseh engine won't start
Old 08-09-16, 04:51 PM
O
Ok so let's start this and see what happens. I have a 13hp Tecumseh engine on a yard master riding lawn mower. The engine will not start so I checked the obvious, I have fuel to the carburetor, and I have spark. If I spray starting fluid in the air cleaner it will start right away and run until the fluid burns off. So I thought I may have a carb problem, so I replaced the carburetor. Still same problem exists. So I am stumped it's as if the fuel isn't going through the carb to the spark plug??? Please help. I will post video if needed.
Old 08-09-16, 05:14 PM
cheese's Avatar
Received 142 Upvotes on 131 Posts
Is the choke closing all the way? Is the carburetor new, or one off another engine?
Old 08-09-16, 05:39 PM
BFHFixit's Avatar
This!?
I think if it were a choke issue, it would continue to run once it started off of juice. !
Old 08-09-16, 07:43 PM
G
Received 31 Upvotes on 29 Posts
Clean the bowl nut, the idle circuit is clogged, it's the tiny hole near the top, almost invisible. Refer to the pic below as an example. Have a good one. Geo
[ATTACH=CONFIG]69448[/ATTACH]
Old 08-09-16, 08:59 PM
cheese's Avatar
Geo is on it, if that's the type carb you have. I'm thinking being a 13hp it may have the one with the plastic bowl. That's why we need an engine model or some other information to go on.
Old 08-10-16, 04:49 AM
B
Received 293 Upvotes on 260 Posts
You may have a bad fuel pump if the fuel tank is at or below the level of the carb float bowl.
