Troy Built Bronco Kohler Engine Won't Start
Received 0 Votes
Have 2010 Troy Built Kohler Engine on Bronco Lawn Mower
Motor cranks but won't start
New Solenoid
Good Battery
New Spark Plug
Good Solenoid Fuse
Fuel filter is good
When cranking get small spark, but you can hold with just a little shock
I've sprayed air filter with starter and gas and still no starting...just turns and turns
New Solenoid
Good Battery
New Spark Plug
Good Solenoid Fuse
Fuel filter is good
You say you're getting small spark. Does that mean you can visually see the spark? Because normally a spark you can see will give you more than just a little shock when you hold the lead. I'm thinking you have a weak coil and you are feeling a little jolt but there is no spark.
Probabley have a bad coil, but disconnect the kill wire that goes from the coil to the wire harness. If you still just get a "little" shock when you hold the lead, you have a bad coil/module.
Don't take everything apart until you try that.
