B&S, 12HP ..new carb and magneto .. runs over rich?!
Old 08-18-16, 01:44 PM
Brand new parts - starts well ..runs pretty good. (starts to stagger at high RPM) ..but I can hardly run at all with an air cleaner in place?! Even without you can see it's over rich by the black exhaust. There's only one needle jet type thing ..moved it to One Turn out from closed.
Could there be dirt in the float bowl holding the pin open? Appreciate any help - thanks. Jim
Old 08-18-16, 01:52 PM
Received 30 Upvotes on 29 Posts
Is that an ebay carb for about 20 bucks?
Old 08-22-16, 12:41 PM
Sorry for the lag in my reply.. No it's the OEM (not close by - forgot name) bought from Amazon. My other B&S use the same mfgr.
Jim
Old 08-22-16, 01:12 PM
Did you try setting the mixture screw in clockwise or does that affect it at all.
Old 08-22-16, 01:30 PM
Start it and warm it up, then with the throttle set at full open shut off the fuel to the carburetor. Watch it closely to see if it starts to clean up before it dies from lack of fuel.
Old 08-22-16, 03:17 PM
BFHFixit's Avatar
What are the engine numbers ?
Old 08-22-16, 11:55 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
